Intermittent failing to POST issue on PC
2 Mar 2024
United Kingdom
Hi all,
My PC has this rather unusual quirk where, on occasion, it will black screen (in Windows), and then will refuse to post (with the VGA light on) until I fully unplug it and leave it. This issue has been present for the last few months, though I haven't been able to find a cause. More recently, however, is that, around 80% of the time, it will get stuck on the BOOT light for around 2 minutes, before then taking about 2 more minutes to get into Windows. When it gets into Windows, it's very slow and Explorer frequently crashes.
I have tried:
- Plugging and Unplugging the Graphics Card
- Resetting CMOS
- chkdsk and sfc /scannow
- Reinstalling Windows
- Windows Diagnostic RAM Test
- FurMark - was slower than previous attempts at same settings
- CPU-Z - CPU shows up fine
- GPU-Z - GPU shows up fine
- Checking Task Manager - everything shows up OK
- Checked Temps - all good
- Swapping SSD out and installing windows on a fresh SSD - no dice (refused to show up in BIOS)
This computer (custom-built) has been a bit of a hassle for me. The previous motherboard died unexpectedly after around 2 years. I'm afraid perhaps something has failed or that perhaps something is failing.
SPECS:
CASE: CORSAIR CRYSTAL SERIES 570X RGB GAMING CASE
CPU: Intel® Core™ i7 Eight Core Processor i7-10700KF
MOTHERBOARD: ROG STRIX B560F GAMING WIFI (according to CPU-Z)
GPU: 6GB NVIDIA GEFORCE GTX 1660 SUPER
M.2 SSD: 1TB INTEL® 665p M.2 NVMe PCIe SSD
PSU: CORSAIR 550W CV SERIES™ CV-550 POWER SUPPLY
CPU COOLER: Corsair H100i RGB PLATINUM Hydro Series High Performance CPU Cooler
EXTRA CASE FANS: 1x 120mm Black Case Fan (configured to extract from rear/roof)
OS: Windows 11 (latest version)
I would appreciate anyone's opinion as I'm at a loss and I can't afford to pay someone to diagnose it
Try replacing the CMOS battery.
Beyond that, take a look at the Adamant IT channel on YouTube for how to diagnose a hardware fault
How does the PC behave in the BIOS and are you on the latest BIOS?
You say the issue has been there for a few months, have you made any hardware/software changes (i.e. Flashed BIOS, BIOS settings change)?
Also I would recommend getting any distro of Linux and popping it onto a flash drive and running a live environment to see if anything changes.
I would also try the above step with the SSD disconnected.
BIOS behaves fine in BIOS - the BIOS isn't the latest, but has been fine since I got the board about 2 years ago. There hasn't been any substantial hardware changes, bar the removal of a HDD and a SSD.
