Hi All, I'm not sure where to go to and hoping someone on the forum could help or recommend someone who could.
I build my daughter a relatively high end gaming PC last summer and it was fine until a couple of months ago when it started freezing when stressed in games. I re-seated all of the components and even replaced the heatsink paste on the CPU which helped for a while but then it slowly got worse to the extent now it won't run for more than a couple of minutes. Even when off for a long period of time, when I look at temperatures in the BIOS everything looks good other than the chipset temperature which is well over 60 degrees.
My current suspicion is either the motherboard is faulty (I have seen a recall but it seems to be related to water-cooling the chipset which I'm not doing) or the power supply isn't sufficient (but I would expect that would have caused issues from day one).
I don't really want to start buying parts to change out without knowing what the cause is so I'm a bit stuck and could use some advice.
The build is as follows:
Thanks,
Stephen
- ASUS ROG MAXIMUS Z690 FORMULA, Intel Z690, S 1700, DDR5, PCIe 5.0, SATA3, M.2, 10GbE/ax WiFi, USB 3.2 Gen2x2/TB4, ATX
- Intel Core i9 12900K, S 1700, Alder Lake, 16 Cores, 24 Threads, 3.2GHz, 5.1GHz Turbo, 30MB Cache, 125W, Retail
- 32GB (2x16GB) Corsair DDR5 Vengeance White, PC5-44800 (5600), Non-ECC Unbuffered, CAS 36, XMP 3.0, 1.25V
- 1TB Samsung 980 PRO, M.2 (2280), PCIe 4.0 (x4) NVMe SSD, MLC 3D V-NAND, 7000MB/s Read, 5000MB/s Write, PS5 Compatible
- ASUS ROG Strix GeForce RTX™ 3080 V2 White OC Edition 10GB GDDR6X with LHR
- Lian-Li UNI SL120 Addressable RGB White 120mm Fan x 10
- Corsair iCUE 5000T RGB Tempered Glass Mid-Tower ATX PC Case — White
- Corsair CX-F RGB Series CX750F RGB 80 PLUS Bronze Fully Modular ATX Power Supply White
- NZXT Kraken Z73 RGB AIO CPU Water Cooler with LCD Screen White - 360mm
Thanks,
Stephen
