can someone have a look at these figures and tell me if there is anything dodgy? cos there is nothing to suggest a correlation between time of day and disconnection or noise/line attenuation and disconnections, not environmental, can be amazing hot or cold or shocking when hot or cold. had the same problems with 2 different ISP's, Tiscali and now with Sky, 2 different routers, belkin and now netgear. different internal cables, new ones were installed by BT shortly before we left tiscali and our problems continued and we thought it was tiscali.
but that only left the cables between our house and the exchange and the exchange itself. i have contacted BT and they have said that there is no problem with the exchange which i dno whether to believe or not considering how much bull they talk..
but here is some of the readings i have taken recently and would appreciate if someone could have a quick look through them.
hope you can understand thatDate: 26th July 2007
Time: 19:17:56
ADSL Link Downstream (Kbps) /Upstream (Kbps)
Connection Speed 160 /416
Line Attenuation(db) 52.0 /31.5
Noise Margin(db) 5.1 /13.0
Speed Test 138 /285
Time: 20:38:51
Connection Speed 1600 /416
Line Attenuation(db) 50.0 /31.5
Noise Margin(db) 22.0 /13.0
Speed Test 1371 /328
Date: 30th July 2007
Time: 01:54:01
Connection Speed 1728 /416
Line Attenuation(db) 49.0 /31.5
Noise Margin(db) 25.6 /14.0
Speed Test 1486 /352
Time: 21:54:52
Connection Speed 416 /416
Noise Margin(db) 7.6 /13.0
Speed Test 353 /297
Time: 22:21:22
Connection Speed 5600 /416
Line Attenuation(db) 48.0 /31.5
Noise Margin(db) 10.8 /13.0
Speed Test 4822 /342
Date: 31st July 2007
Time: 19:02:17
Connection Speed 832 /416
Noise Margin(db) 2.3 /14.0
Speed Test 722 /340
Date: 1st August 2007
Time: 22:26:59
Connection Speed 512 /516
Noise Margin(db) 8.7 /13.0
Speed Test 442 /337
Date: 2nd August 2007
Time: 00:04:16
Connection Speed 288 /416
Line Attenuation 52.0 /31.5
Noise Margin 10.2 /13.0
Speed Test 248 /304
