I am having a problem with my car where will not starting every so often/has problems starting. I thought it might be the battery so i removed it and charged it up with a battery charger. After charging it up overnight over 12 hour+. I tried starting the car, it would not start until trying to 3 or 4 times. I then drove the car for about 15-20 mins and parked the car. I then tried to start the car again.. it would not start properly, the engine would start and end shut/cut off. After trying about 5 or 6 times the car started fine and runned fine. I drove the car fine again without any problems starting and stopping the car several times. I brought a multimeter today and tested the battery and alternator this evening and the readings were fine.
Battery reading approv 12.6V and with engine on 14.9V. So both the battery and alternator seems to be fine. On starting the car batterys drops 10.5V for a bit.
I tried leaving the car headlights on the car for 5 mins before taking a voltage reading and it was 12.6V.
The car is 2001 1.6 ford focus and the battery is about 2.5 years old
What other things I can check to see what could be causing my car starting issue?
Thanks in advance
Thanks in advance
