Please can anyone help me here. I have tried the following:
Memtest run all tests for over 2 hours no errors whatsever.
Played GPU intensive games for 5-6 hours with perfect stability (Nvidia GTX 780 Ti @ 2560x1080 max details).
Intel Processor Diagnostic Stress tests.
System cooling is always ok when this happens no temp spike the CPU is around 35-40C away from the max TDP.
No viruses anywhere.
Now sometimes its impossible to tell when but I suddenly get a reboot always without warning whilst on the Win 7 x64 desktop or using IE 11 to browse.
Also now & again I have to from cold restart the PC as it does not initialise the Intel Lan port first time from cold but 2nd time it works fine.
I am thinking either the following:
Motherboard is failing & or has faulty caps.
CPU is failing.
PSU is failing (Seasonic 750W X series 80 plus Gold just over 2 years old).
The motherboard & CPU are over 5 years old (Intel Core i7-980x @ 3.33Ghz stock frequency with 3.46Ghz turbo clocks. Its been run like this at stock since new).
This never ever happens under heavy load its always a light load on the PC when this happens.
Please can anyone tell me what they think & or offer any suggestions to isolate the problem which sometimes does not happen for weeks then suddenly without warning it happens like earlier today & never leaves an event viewer entry either just the usual power was interputted restart error.
There is no pattern to this its always random I am going to have trouble buying another EX58 Socket 1366 CPU motherboard as they stopped making them about 3 years ago
CPU is failing.
