I decided to give lucid virtu mvp a go today, I went into the bios, turned the internal graphics on, set it to auto detect which graphics to use, saved, turned off, plugged my monitor into the on board dvi, turned it on and nothing!
Swapped the monitor back into the hd 7850, restarted and it was back on, checked the bios, my settings had saved, tried changing to use internal graphics first, saved, turned off, plugged monitor into onboard dvi, turned on and still nothing!
The monitor only works in the hd 7850, the internal graphics don't show up in device manager no matter what settings I use, lucid virtu mvp won't install because it says no onboard graphics detected.
It was working perfectly for months before I bought a separate graphics card.
Spec is, ga-z77-d3h (19g bios), i5 3570k, sapphire hd 7850 2gb oc edition.
Any ideas?
Any ideas?
