Internal insulation query
22 Nov 2010
Backstory: I have a bedroom in my house at the back of the house which is incredibly cold in the winter and ridiculously hot in the summer. In the winter the walls feel very cold to the touch. The roof is inaccessible and sloped, when I was doing up the room I made a few holes in the ceiling and could see insulation in rolls in packaging within the room space.
If anything fabric is touching the walls for a while it goes mouldy, the walls can get occasional mould patches.
I'm suspecting water ingress is coming through the bricks?
Would some foil and insulated plasterboars make the room normal? Would I get mould issues and would that plasterboard be ok on the ceiling?
Why is it you’re not able to access the loft?
It’s not likely that water is coming through the bricks to be honest, not on that level.
It is far more likely lack of insulation which is causing the condensation.
Foil backed plasterboard might help a little bit but you’re not addressing the root cause.
How old is the house?
If you can find a way of getting to the loft and sorting out what appears to be insufficient insulation that will help.
Is the bedroom at ground level?
Where in relation the the floor is the mould appearing?
It sounds like an insulation problem ie there isn’t much/any.
What age is the property?
Do you have any heating in it?
Have heating yes, radiator in the room.
Property is around 115 years old
No hatch, is the rear part of the house with a sloping roof. Hence wanting to insulate (even only a little) with the backed plasterboard.
Main part of the house large loft.
I don't think we have a cavity in this part of the house.
If the room is part of the original house then they will be solid brick - one stretcher and one header - most likely for a house that is 115 years old.
If the room is actually an addition then, it may be single skin which is not only awful for insulation, is also fairly insubstantial.
Either way, you have solid/single skin walls with no cavity which are externally facing. So, when you place an item against these walls, the air temperature internally is much higher than the temperature externally causing condensation to build up on the internal face of the wall.
So, anything touching the wall becomes wet and begins to go mouldy.
That’s your issue. Insulating the roof will do nothing.
Best to keep items away from the walls - the only solution from that point would be some sort of externally applied cavity insulation or cladding
I had this exact situation.
I tore the roof down and found old insulation blocking airflow and evidence of old leaks (fixed by the new roof)
I carefully re insulated the roof and I have just battened the walls out with 50x50mm timber leaving a 10mm gap and filled the stud work with 50mm celotex.
Room is warmish (no radiator in it yet)
its deffo part of the original house so solid brick. my assumption was that a (as below) celotex type insulation with foil would stop thermal issues causing the condensation?
this is kind of what im thinking but without taring of the roof
Yes that could work provided you can loose some room space?
I'm willing to sacrifice some room space, (2 walls are externally facing) so wouldn't be too much of an issue.
Currently my 2 daughters are sharing a room and the small cold room is a dumping ground/occasional room but don't fancy letting one of the girls have it as a full time bedroom with potential mould issues.
if its as bad as it sound then I wouldn't insulate it without stripping the ceiling and inspecting it and taking it back to bare brick.
If you insulate over a damp issue the next you will know of it could be when you have structural rot
Or you could externally insulate the walls and render. This is quite a common method of improving properties insulation where it is not possible to use an internal solution.
If you can lose some rome space can you add a cavity? Venting it properly (to the outside) would be needed though.
little point in doing this as the floor and roof structure are supported by the external wall.
Having just done this, taking the ceiling down and floor boards up isn't much extra effort for doing it properly and safely :rolleyes:
I had a similar problem in our third bedroom in a 115 year old house
Smallest room with the biggest external wall meant it was always cold
Ended up studding the wall with insulation in between that and new foil backed plasterboard then reskimmed
Lost about 50-75mm space in the room but it much improved the room that you can actually go in there now
