Hi all,
Does anyone know if its possible to get extension cables for the internal PSU cables - particularly the motherboard and CPU power supply cables (and maybe the PCI-Express cables, too).
Reason being is that I just bought a Fractal Design Define XL case and lovely as it is, having my PSU at the bottom of the case is a real restriction to the cable lengths. The CPU cable runs - very tightly - over the top of my graphics card and only just reaches the connector. This means that it, along with the motherboard power supply and the PCI-Express cords are all too short to route around the back of the motherboard tray and it ruins one of the great advantages of this case (namely, having the internals free of cable clutter)
So, does anyone know where I might be able to get extensions for these cables? I had a check in the cables section on OcUK, but they didn't seem to have any (only molex extension leads, which I don't need!)
