Internal pwm fan controller needed
5 May 2012
Hi
For some reason pwm headers on my MB are playing up, fans would work quietly and then all of a sudden they at 100%, despite bios settings being on quiet. So I need pwm internal fan controller to work with my Corsair ML white fans
I found this little thing from noctua but not sure if my LEDs on fan would work
https://www.overclockers.co.uk/noctua-na-fc1-fan-controller-fg-05l-nc.html
NA-FC1 Fan Controller
Please help me out as I am going crazy ;D
ps also I got corsair 110GT and I'm controlling rad fans plus top fans from that (4 in total)
If this can take 6 fans ill just buy pwm spliter byt not sure if it will run 6 fans
Thanks
Pete
You could get an aquaero fan controller, I still have one that I only used for a week, but my new motherboard has a fan controller built in so the aquaero is now redundant. But the level of control it gives is amazing, better than anything built into even the latest motherboards.
I need internal one like this little noctua or something similar, as I do not have 5,25 bay. Also price is a bit ridicules on those units. I have ordered Noctua na-fc1 from oc uk(hope it works with ML fans) but if any one got any other ideas please feel free to chip in.
thanks
Oh sorry, I though you wanted a software controlled fan controller, yeah the aquaeros is overkill, it's meant for water cooling setups for pumps. I bought the cheapest one they had (still a pricey £50), it didn't go in a bay, I just hid it next to the PSU. The noctua you chose is probably your best bet then. :)
Hi if you look on the Ocuk site phanteks do a pwm controller up to 8 I think in total for £15-£16
Did look on this pahantex but I was unsure how would i be able to control speed of my fans as I said my headers on MB are playing up so ill need some kind softweare to adjust rpm
Grab one of these.
Only a single pwm header but enough to drive at least 12 120mm fans at full speed. As I had them using my ml120's at one point.
https://www.overclockers.co.uk/aqua-computer-aquaero-5-lt-usb-fan-controller-wc-011-aq.html
If you had access to mm I'd sell one of mine I have spare.
Seen it but it looks a bit to complicated for me
200+ posts no access to MM just yet :)
Thanks
