We're on a very old version, so instead of blinding upgrading, I thought Id see if there were any alternativesWhy would you want an alternative out of interest. Dameware is absolutely awesome ?
Logmein is web based tho, so the security team would have issues with itlogmein has lots of derivatives..
personally i use hamachi & realvnc to manage pc's that i make for people (i set both to non auto start, then when i need to do work, i get them to turn them on and create a new temporary network) works for me, but it's not ideal for corporate use tbh
It would be about 3k for us to upgrade. I need to make a justification as to why we need it, but cant seem to find many differences in the versionsIf cost is an issue then VNC would be my second choice although it can be a tad on the slow side in my experience.
If you have 60 sites then you are obviously a fairly big organisation, I would seriously consider putting a plan together for an upgrade to Dameware, its a flawless product as far as I have seen.
A[L]C;11425034 said:It would be about 3k for us to upgrade. I need to make a justification as to why we need it, but cant seem to find many differences in the versions
We could do, but change is good!Its probably mainly security related but also you would get continued support from them should you encounter any issues. They also offer other products too which they might bundle you in with.
If you are happy with the current version, can you not just stick with that ?
VNC Enterprise Edition
http://www.realvnc.com/products/enterprise/index.html
A bulk purchase of around 60 licenses will get a fairly big discount
