Internal usb c extension cable?
18 Dec 2008
Liverpool
Okay, so the way I've had to route my front panel cables in my recent build has rendered my front panel usb c cable to short to reach the motherboard. I've had to run down and under a side rad. Is there some sort of extension cable as I cannot find one available anywhere?
My gigabyte board uses an F_U320G socket for the USB-C header. I assume that's a widely used socket for USB-C headers across manufacturers, but I could not for the life of me find an extension for it either.
In the end I had to reroute it as best as I could, which sounds like you'll have to do the same, or go without connecting up the front ports.
fleabay
ADT-Link USB3.1 GEN2 Type-E to Type-E Extension Cable USB 3.1 E Type Cable​
various sizes.looks like we needed the correct terms/description
