- 20 Jan 2005
- Leeds/Oxford
Hi, i turned my computer ontoday to get a "network connection has limited or no connectivity" icon after it workingfine since i built my PC months ago. Other PC'son the same network are working fine which is odd. I've tried repairing, uplugging, restarting, a different network card, a USB to ethernet converter. None of which have worked
I also tried re-setting it to auto find IP, and also chenged the IP to what it normally is which also didn'twork.
I'm about to try a program called WinSock XP which i dont trust at all but is the only thing i managed to get off google that might work. Before i try that is there anything else that might work?
Many thanks
Many thanks
Sandy! L337 haxord my account!
