Internet Explorer keeps popping up with adverts/pop ups?
26 May 2008
Hi all,
For some reason Internet Explorer has opened by itself a few times today with pop ups, I don't use it prefering Firefox, any ideas why it is comming on by itself?
Cheers
Running a scan now as Itype,
Any of this seem an issue?
The bit highlighted in blue turned itself back on after being taken out the start menu?
Sounds like spyware, download malwarebytes to a usb pen, turn off system restore, and install it and run it from safe mode.
That'll hopefully eliminate your infection.
OK to update,
I had ad-aware, superantispyware, Avira, Mirosoft security, none of which detected it, though Avira and Microsoft found and quarantined a couple of items without stopping the process. Malaware bytes froze without finding or solving initially.
I ended up tracing a couple of apps to the temp folder? You can see the three ones which start with X above. I could not delete these, so I stopped the processes then deleted then cleaned the HD re-started and ran my spyware, Malaware Bytes to be exact, which found the process highlighted in blue in my start menu. I have had no pop ups since deleting the above three apps, I have no idea where they came from, but am dissapointed as it's my fisrt ever PC infection that has caused such bother on W7.
I am wondering if this may have been linked to my being unable to load C&C4 due to Windows Installer 5 going missing, as it seemed it could have have been linked to those directories? And Adobe would not update either last week?
Well fingers crossed!
Cheers guys
