Internet keeps dropping connection
17 Dec 2007
Easington Lane
Hi all i had a problem a few months back where every minute my internet would lose connection. It turned out it was due to a fault with the extension line i was using so i am using my router plugged directly into the master socket. Job done and has now doubled my download speed.
Problem im having now is it starting to drop connection but there are no disconnections on the line. Im using a o2 wireless box and a cheap 56mbps wireless card.
I have checked to make sure that windows is not turning off the card to save power so it has got me thinking that the wireless card must be at fault.
What would people recommend as a half decent wireless card to replace mine with? Could only really go up to around £25-£30.
Also when i go into the router setting's it tells me it is running at around 4.8meg download and 1.2meg upload but speedtest.net tells me around half that.
Thank you
Just been having a look around and think it might be best to upgrade my router aswell. So how does getting a Sweex LW300UK DSL Router 802.11n 300mbps Broadband Router and a Edimax EW-7728IN / PCI Wireless N WiFi Card / 300mbps / 802.11n sound? Should be better than what im using now
What is your wireless signal like? There may not be a fault with it, but that your house is just not wireless friendly.
I couldn't use wireless and got my connection from the router to my room with ethernet over power homeplugs.
The signal stays around 3 bars out of 5. It really only happens when i move the computer upstairs
