Internet or I.E problems
16 Jan 2006
Internet
Hello,
Am having internet problems i think.
I can ping the bbc.co.uk web site not a problem. i get an ip address from the router and all the lights are as normal it worked fine and all of a sudden it wont load any web pages any more,
I had f secure on the computer but i have taken that off using add/remove programs. its running windows xp and am with orange on a Dlink router. and i have 2 computers on the router and both are the same.
everything is on DHCP but for some reason i can not get online it starts to load the home page which is orange but after about 40mins it loads half the site.
What i want to know is
could it be the
router
I.E
Software
I have had the line tested and its fine and i have changed the microfilter
any help would be brilliant
Thank you
