PrintWindows Network Diagnostics Publisher details
Issues found
The DNS server isn’t respondingThe DNS server isn’t responding
Your computer is trying to use a DNS server that is incorrect or doesn’t exist. Detected Detected
Contact your network administrator Completed
Issues found Detection details
6 The DNS server isn’t responding Detected Detected
Detection details Expand
InformationalDiagnostics Information (Network Adapter)
Details about network adapter diagnosis:
Network adapter WiFi driver information:
Description . . . . . . . . . . : Qualcomm Atheros QCA9377 Wireless Network Adapter
Manufacturer . . . . . . . . . : Qualcomm Atheros Communications Inc.
Provider . . . . . . . . . . . : Microsoft
Version . . . . . . . . . . . : 12.0.0.722
Inf File Name . . . . . . . . . : C:\Windows\INF\netathr10x.inf
Inf File Date . . . . . . . . . : 07 December 2019 09:07:47
Section Name . . . . . . . . . : ATHR_DEV_OS63_988x_AC_NFA435_TF11.ndi
Hardware ID . . . . . . . . . . : pci\ven_168c&dev_0042&subsys_08a611ad&rev_31
Instance Status Flags . . . . . : 0x180200a
Device Manager Status Code . . : 0
IfType . . . . . . . . . . . . : 71
Physical Media Type . . . . . . : 9
InformationalDiagnostics Information (Wireless Connectivity)
Details about wireless connectivity diagnosis:
Information for connection being diagnosed
Interface GUID: 662c8d9d-7bc8-4041-adf5-f13a4308b29b
Interface name: Qualcomm Atheros QCA9377 Wireless Network Adapter
Interface type: Native WiFi
Connection incident diagnosed
Auto Configuration ID: 8
Connection ID: 5
Connection status summary
Connection started at: 2024-10-27 06:27:13-049
Profile match: Success
Pre-Association: Success
Security and Authentication: Success
List of visible access point(s): 1 item(s) total, 1 item(s) displayed
BSSID BSS Type PHY Signal(dB) Chnl/freq SSID
D6-35-1D-66-C6-5D Infra <unknown> -42 5280000 40 Christ Church Street
Connection History
Information for Auto Configuration ID 8
List of visible networks: 12 item(s) total, 12 item(s) displayed
BSS Type PHY Security Signal(RSSI) Compatible SSID
Infra <unknown> Yes 100 Yes 40 Christ Church Street
Infra <unknown> Yes 100 Yes (Unnamed Network)
Infra <unknown> No 100 Yes EE WiFi
Infra <unknown> Yes 85 Yes BT-2TFJX7
Infra <unknown> Yes 57 Yes SKYXBXYE
Infra <unknown> Yes 100 Yes BT-WCA652
Infra <unknown> Yes 77 Yes VodafoneMobileWiFi-2B6C8B_2.4G
Infra <unknown> Yes 100 Yes Thunder
Infra <unknown> Yes 70 Yes BT-RHCWMQ
Infra <unknown> Yes 77 Yes VodafoneMobileWiFi-2B6C8B_2.4G_5
Infra <unknown> Yes 95 Yes EE WiFi-X
Infra <unknown> Yes 46 Yes EE-32W9WM
List of preferred networks: 3 item(s)
Profile: 40 Christ Church Street
SSID: 40 Christ Church Street
SSID length: 23
Connection mode: Infra
Security: Yes
Set by group policy: No
Connect even if network is not broadcasting: No
Connectable: No
Reason: 0x00028001
Profile: Thunder
SSID: Thunder
SSID length: 7
Security: Yes
Connectable: Yes
Profile: STEWARTS
SSID: STEWARTS
SSID length: 8
Security: Yes
Connectable: No
Reason: 0x00028003
Information for Connection ID 5
SSID length: 23
Security: Yes
Pre-Association and Association
Connectivity settings provided by hardware manufacturer (IHV): No
Security settings provided by hardware manufacturer (IHV): No
Profile matches network requirements: Success
Pre-association status: Success
Association status: Success
Last AP: d6-35-1d-66-c6-5d
Configured security type: WPA2-PSK
Configured encryption type: CCMP(AES)
802.1X protocol: No
Key exchange initiated: Yes
Unicast key received: Yes
Multicast key received: Yes
Number of security packets received: 0
Number of security packets sent: 0
Security attempt status: Success
Connectivity
Packet statistics
Ndis Rx: 0
Ndis Tx: 0
Unicast decrypt success: 11
Multicast decrypt success: 0
Unicast decrypt failure: 0
Multicast decrypt failure: 0
Rx success: 0
Rx failure: 0
Tx success: 225
Tx failure: 0
Tx retry: 0
Tx multiple retry: 0
Tx max lifetime exceeded: 0
Tx ACK failure: 0
Roaming history: 0 item(s)
Information for Connection ID 4
Connection started at: 2024-10-27 06:17:10-394
Profile: Thunder
SSID: Thunder
SSID length: 7
Security: Yes
Last AP: 32-ab-6a-1c-30-cd
802.1X protocol: No
Connectivity
Packet statistics
Ndis Rx: 0
Ndis Tx: 0
Unicast decrypt success: 996
Rx success: 0
Rx failure: 0
Tx success: 483
Tx failure: 87
Tx retry: 0
Tx ACK failure: 0
Roaming history: 1 item(s)
Times: 2024-10-27 06:27:13-043
Roamed from BSSID: 00-00-00-00-00-00
Reason: 0x00000007
Disconnected from BSSID: 00-00-00-00-00-00 Reason: 0x00000101
Information for Auto Configuration ID 7
List of visible networks: 0 item(s) total, 0 item(s) displayed
List of preferred networks: 0 item(s)
Information for Auto Configuration ID 6
Infra <unknown> Yes 28 Yes BT-RHCWMQ
Infra <unknown> Yes 95 Yes BT-2TFJX7
Infra <unknown> Yes 90 Yes SKYXBXYE
Infra <unknown> No 85 Yes Bedroom TV.v,
Infra <unknown> Yes 97 Yes VodafoneMobileWiFi-2B6C8B_2.4G
Infra <unknown> Yes 80 Yes VodafoneMobileWiFi-2B6C8B_2.4G_5
SSID length: 23
Security: Yes
Connectable: No
Reason: 0x00028001
Profile: Thunder
SSID: Thunder
SSID length: 7
Security: Yes
Connectable: Yes
Profile: STEWARTS
SSID: STEWARTS
SSID length: 8
Security: Yes
Connectable: No
Reason: 0x00028003
Information for Connection ID 3
Connection started at: 2024-10-27 06:16:43-936
Auto Configuration ID: 6
Profile: Thunder
SSID: Thunder
SSID length: 7
Security: Yes
802.1X protocol: No
Connectivity
Packet statistics
Ndis Rx: 0
Ndis Tx: 0
Unicast decrypt success: 222
Rx success: 0
Rx failure: 0
Tx success: 0
Tx failure: 0
Tx retry: 0
Tx ACK failure: 0
Times: 2024-10-27 06:17:03-675
Reason: 0x00000007
Disconnected from BSSID: 00-00-00-00-00-00 Reason: 0x00000205
For complete information about this session see the wireless connectivity information event.
Helper Class: Auto Configuration
Initialise status: Success
Result of diagnosis: There may be problem
InformationalDiagnostics Information (Wireless Network Adapter)
Details about wireless network adapter diagnosis:
Helper Class: Native WiFi MSM
SSID length: 23
Security: Yes
InformationalNetwork Diagnostics Log
File Name: 7C483DD9-5BDD-46B7-A843-38F64868F746.Diagnose.Admin.0.etl
InformationalOther Networking Configuration and Logs
File Name: NetworkConfiguration.cab
Collection information
Computer Name: ASHLEYS-LAPTOP
Windows Version: 10.0
Architecture: x64
Time: 27 October 2024 06:39:04
Publisher details Expand
Detects problems with network connectivity.
Package Version: 4.0
Publisher: Microsoft Windows
