** INTRODUCING MODFLEX FROM CABLEMOD **
rjk
rjk
Caporegime
8 Aug 2007
Hi Guys
It gives me great pleasure to announce another innovative new product from CableMod today. The ModFlex system allows you to easily and quickly create custom braided cable combinations without the need for time consuming and fiddly modding tools.
The Sleeved wires come in three lengths to suit your own requirements and feature the same ModFlex sleeving used on the premium cable kits from CableMod
All you have to do is buy the connectors and enough cables to populate them and you are good to go. No tools are required to do this and each cable comes with a colour coded protector on it which you match to the CableMod connector.
Full Range
Highlights:
CableMod ModFlex Connector Pack - 24 pin ATX - schwarz @ £2.09 inc VAT
Designing your very own custom cable extension is easy with CableMod Connectors. This set of connectors comes with one female and one male variant, is designed to work perfectly with our ModFlex™ Sleeved Wires.
Assembling your own custom cable extension is easy. One connector has a white sticker while the other one does not. The ends of each ModFlex Sleeve Wire are fitted with a color-coded silicone protector. Simply remove the protector, match that color with the color code on our CableMod Connector, and insert the wire - it's really that easy.
With several connector types available, CableMod Connectors can help you achieve that one-of-a-kind look for your PC.
Inside the package:
1 x 24 pin Female ATX connector - BLACK
1 x 24 pin Male ATX connector - BLACK
Only £2.09 inc VAT.
ORDER NOW
CableMod ModFlex Connector Pack - 6 pin PCI-e - Black @ £1.39 inc VAT
Inside the package:
1 x 6 pin Female PCI-e connector - BLACK
1 x 6 pin Male PCI-e connector - BLACK
Only £1.39 inc VAT.
ORDER NOW
CableMod ModFlex Sleeved Cable, Purple 20cm - 4 Pack @ £2.99 inc VAT
Ever wanted to customize your own cable extensions to match your unique build? Now you can with CableMod ModFlex™ Sleeved Wires.
These sleeved wires feature the very same ModFlex sleeving featured on our premium cable kits for a luxurious look and supreme flexibility. No heatshrink ensures a clean look, and each and every wire is precision cut to the same exact length for optimal results.
Assembling your own custom cable extension is easy and tool-free. The ends of each wire are fitted with a color-coded silicone protector. Simply remove the protector, match that color with the color code on our CableMod Connectors, and insert the wire - it's really that easy.
Available in a multitude of colors and lengths, the only limit to what you can do with ModFlex Sleeved Wires is your own imagination.
Inside the package:
4 x (20cm) ModFlex Sleeved Wire
Only £2.99 inc VAT.
ORDER NOW
CableMod ModFlex Sleeved Cable, Green 20cm - 4 Pack @ £2.99 inc VAT
Inside the package:
Only £2.99 inc VAT.
ORDER NOW
CableMod ModFlex Sleeved Cable, Red 40cm - 4 Pack @ £3.59 inc VAT
Inside the package:
4 x (40cm) ModFlex Sleeved Wire
Only £3.59 inc VAT.
ORDER NOW
CableMod ModFlex Sleeved Cable, Light Green 60cm - 4 Pack @ £4.25 inc VAT
Inside the package:
4 x (60cm) ModFlex Sleeved Wire
Only £4.25 inc VAT.
ORDER NOW
