OcUK Staff
- 26 Nov 2014
- Stoke
Now available for pre-order and in stock in the next few days, we have the new models from Kolink - Observatory Lite, Observatory Lite Mesh & Inspire K7. Starting with the Observatory Lite/Lite Mesh, these are a more cost effective version of the vastly popular Observatory model. Offering both glass or mesh front panels, both models come equipped with 4 ARGB ring fans, which can be controlled via the supplied remote or via compatible motherboard software. There's a range of effects and modes available using the remote, including fan speed control. Both models have tempered glass side panels, PSU shrouds, support for up to ATX motherboards, 335mm VGA cards, 280mm radiators on the front panel and more. Whilst the mesh version will be better for airflow, the increased front panel depth and side intakes on the glass model will provide sufficient airflow regardless. Both models will be available in the next few days and once again offer great value for money.
In addition the above, we also have the Inspire K7 Midi Tower arriving soon. The Inspire K7 is another addition to the popular Inspire series of cases, featuring an angled ARGB LED strip on the front panel, alongside a carbon fiber effect finish and mesh ventilation holes. There's a rear 12cm ARGB LED fan included as standard, which is connected to the front ARGB strip and can be controlled either using the RGB button on the I/O or connecting to compatible motherboards and controlled through their software. Like the Observatory Lite, there is space for ATX motherboards, 335mm VGA cards, 280mm radiators on the front panel & 160mm CPU coolers. Stock will be here any day now and for just a shade over £40, represents another solid addition to the Kolink range.
Kolink Observatory Lite ARGB Midi Tower Gaming Case - Black @ £54.95 inc VAT
Outstanding Midi-Tower from Kolink, 4 x pre-installed 120mm aRGB fans, Tempered glass side panel, PSU shroud, RGB Remote with Effects & Speed Control, EPE Foam Packaging
Only £54.95 inc VAT.
ORDER NOW
Kolink Observatory Lite Mesh ARGB Midi Tower Gaming Case - Black @ £54.95 inc VAT
Outstanding Midi-Tower from Kolink, 4 x pre-installed 120mm aRGB fans, Full Mesh Front Panel, Tempered glass side panel, PSU shroud, RGB Remote with Effects & Speed Control, EPE Foam Packaging
ORDER NOW
Kolink Inspire Series K7 ARGB Midi Tower Case - Black @ £42.95 inc VAT
Great value Midi-Tower from Kolink, Front ARGB LED Strip, Carbon Fiber Effect Front Panel with Ventilation, Rear 12cm ARGB LED Fan, Tempered glass side panel, PSU shroud
Only £42.95 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
