OcUK Staff
- 26 Nov 2014
- Stoke
Available for preorder today, we have the new range of Metis Evo cases from Raijintek. These represent a significant upgrade on the original Metis lineup. For starters, there's much improved airflow with a mesh front panel, allowing up to a 200mm fan to be installed. There's also space for a 120mm fan at the bottom, and 2 x 92mm fans at the rear. Despite it's small form factor, the Metis Evo range can support dual slot VGA cards up to 280mm with Mini-ITX motherboard support, 135mm CPU coolers, 2 x 2.5"/3.5" and a further 2 x 2.5" drives, ATX or SFX PSU's and even up to 200mm radiators! The exterior is made of 2mm aluminium with the option of either tempered glass or solid aluminium side covers. With Black, White, Red, Blue and Silver variants on the TG version, plus Black, White & Silver options for the ALS models, there's plenty of choice to suit your particular aesthetic.
Stock will be available approx mid November, so preorder now!
Raijintek Metis Evo Mini-ITX Case - Black Window @ £119.99 inc VAT
Mini-ITX case, brushed aluminium exterior, dual tempered glass side panels, pre-installed 200mm front fan
Only £119.99 inc VAT.
ORDER NOW
Raijintek Metis Evo Mini-ITX Case - Silver Window @ £119.99 inc VAT
ORDER NOW
Raijintek Metis Evo Mini-ITX Case - White Window @ £119.99 inc VAT
ORDER NOW
Raijintek Metis Evo Mini-ITX Case - Blue Window @ £119.99 inc VAT
ORDER NOW
Raijintek Metis Evo Mini-ITX Case - Red Window @ £119.99 inc VAT
ORDER NOW
Raijintek Metis Evo ALS Mini-ITX Case - Black @ £119.99 inc VAT
Mini-ITX case, solid brushed aluminium exterior, pre-installed 200mm front fan
ORDER NOW
Raijintek Metis Evo ALS Mini-ITX Case - White @ £119.99 inc VAT
ORDER NOW
Raijintek Metis Evo ALS Mini-ITX Case - Silver @ £119.99 inc VAT
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
