- 16 Nov 2003
- On the pale blue dot
Hi guys. I have a fairly old laptop here that had a pretty bad hard drive crash, meaning I had to go out and buy a new HDD for it. The old HDD contained the recovery partition so I had to install from scratch using the XP CD. Annoyingly the CD key on the sticker on the laptop refuses to work with the installer, so I used my PC's key to at least install Windows, thinking I can then switch the keys during activation.
So I try and use change product key in activation, but it won't accept the key. It gives me an 0800 number to call, but this is just automated and tries to take me through the activation process.
Has anyone experienced this before and if so, how did you fix it? Failing that, how can I get in touch with Microsoft? I'm having no luck with the numbers on their website.
