Inverted case?
12 Mar 2013
Grimsby UK
Hi all,
I’m looking for a case for a new build that is inverted like the Corsair 600c. I would like the pc visible on the other side than that is normal and the gpu facing upwards.
Is there anything available or good nowadays like this?
Possible issue with upside down design is heat easily collecting on upper part of the case, unless top panel has exhaust fan/two, or intake pressure is strong and there are holes near rear top to allow intake airflow to push heated air out.
Most modern graphics cards simply dump their heat into case.
