Inverted motherboard case.
7 Aug 2009
London
HI guys,
Looking to replace my existing case with something that has an inverted motherboard tray as I want my GPU to be at the top next to the top fans.
I used to have a Lian Li A05 that had this design and it was by far the coolest case I've ever owned.
I was looking at this and it seems to be a great budget deal, anyone have any experience of it?
http://www.overclockers.co.uk/showproduct.php?prodid=CA-151-BX
I own an inverted case, which I actually prefer to the normal orientation as the heat from the graphics doesn't interfere with the CPU heat sink. Just need good ventilation at the top of case. I've had experiences with a few bitfenix cases, for the money they are pretty good. Obviously a lot of plastic but the build quality is on the most part pretty good.
Thanks mate, gonna go ahead and order this bitfenix. I find with these inverted atx cases they are either cheap or very expensive!
