Inverter/reversed case
1 Jun 2020
Been scouring the web for a new case. My set up has my pc located on the left hand side of my desk and I want it on show however the case I have currently has it turned the wrong way so you can see into it. Been trying to find a new case but with a twist. Would like the ‘glass’ panel to be on the right side of the tower. I know there are a handful of cases like that but it’s a pain trying to find them. I’d need one that would be able to clear a noctua d15 chromatic which I believe is 165mm? Any chance anyone could lend a hand? Cheers in advanced
view
The old Antec cube was inverted ITX with 190mm cooler clearance, not sure how easy one might be able to find one if you're looking for something small.
