Invisible Door Stops?
18 Oct 2003
Midlands
Hi all,
Has anyone used anything like this as a door stop? https://www.amazon.co.uk/gp/product/B076B355RJ/ref=ox_sc_act_title_1?smid=A2N58YCCQNSUNR&psc=1
My case is a bit different in that I can't screw anything to the floor (underfloor heating pipes) and the door is hitting a piece of wall that hangs down from the ceiling where the stairs encroach on the room. So my plan is to stick one of these to the wall that hangs down so the door can't smash against the plaster.
Are there any better alternatives? I like the idea of clear because it's less visible, I'd like to go as unobtrusive as possible.
Thanks
