Caporegime
- 18 Sep 2009
- Dormanstown.
Hi,
I've currently got a Samsung Frame 43" (Can't remember the generation, think it's a 2021 model) in our kitchen on the shoe storage unit.
I'm wanting to wall mount that and get a "frame" for it so I can actually use it for its purpose. I've only managed to get it properly set up in so far as it'll always display an image as it sees someone walking past.
At the moment it's only got a very cheap and crappy sound bar that I won't be using when I actually wall mount the TV, and so therefore I'm somewhat curious about where I go for the audio.
I was looking at some inwall speakers as a potential possibility from an aesthetics point of view.
I've had a look at my wall and measured the depth, it's 9.5CM end to end. I've actually got a good picture to show the depth. On the other side of the TV it's our downstairs bathroom
The speakers I've been looking at for the moment are - https://www.richersounds.com/catalog/product/view/id/118983/s/bowers-wilkins-cwm362/ and that's about the absolute top end I'd go for the speakers, in fact I'd been looking at the polk audio ones as well which come in about ~£200.
My question is, is it actually feasible to install the speakers into the wall? The depth of the speakers says 7.6CM.
I've got the gist on installing, find the joists and then cut out the template. I'm comfortable enough running the speaker cable to where I need (I do run a bit of data at work when required and it's not worth paying a contractor)
There's a Nest Hub Max in the kitchen, so the speakers would realistically only be used for the TV.
I haven't particularly thought about amp yet, but I can worry about that later. It's just about working out feasibility of inwall speakers.
There's also a chance I end up with a set of Sony HT-AX7 speakers as there's a promotion with a Sony Xperia 1V and my phone contract is due up, so I could just go down that route for convenience.
Cheers.
Cheers.
