Inwin 303
I've got one that I've had for a few months now.
It's a lovely case, there's a few flaws with it though. Thermal performance isn't great, the intakes are on the bottom and have a dust filter, I'm testing currently to see if raising the case up slightly makes any performance gains in temperatures but it's a bit too early still to say.
Some of the cut outs for cable management are a bit odd, it would have been nice to have one under the PSU so the 4 pin power to the mobo could be hidden away, at the moment its sort of trailing along the top edge of the board.
The 3.5" drive goes on the back of the motherboard and doesn't receive any cooling, could cause issues but I removed my 3.5" drive and just stuck with some SSD's.
It is a fantastic looking case though, the tinted tempered glass side panel looks awesome and with a few lights behind, it really does look great.
If you have any questions about it, do let me know.
That's great thanks for the reply, I will be sticking to ssd's so the 3.5" drive issue will not affect me.
Whats the rest of the cable management like as I do normally like to build with a nice clean, cable free inside, especially as it will be so visible.
Everything else is actually quite good, it's just that one power cable that feeds the motherboard that's a nuisance :p
It's a great case and I quite like mine, there's a good amount of space behind the motherboard to hide cabling (I've got a ton of cables behind mine along with an 8 way PWM fan controller).
Well I have ordered one, should arrive tomorrow and got myself some Corsair HD120 fans to go in it so should look good sat on the psu cage. Just need to grab a half decent gpu as my little 1050ti might look lost in there :D. Thanks for the advice Atari.
You've made a great choice. Very easy case to work in and not too difficult to create a great looking build. See Titanium build in my sig... I went a little OTT though lol! ;)
DEFINITELY look at Legend's build :cool: maybe after you've had the case a while so you're suddenly not disappointed with your case looking all standard :p
Haha, yeah, but word of advice... don't vinyl wrap it unless you're a masochist! It was such a pain, I won't be doing that again in a hurry!
Yeah saw your build, looks stunning, I will not be going to them lengths and would not have the time or energy for the vinyl wrap :)
Well it turned up today and I must say it is a stunning looking case, minimalistic but stylish, looking forward to swapping my bits across over the weekend.
Enjoy! I was particularly impressed with the little pack they gave with all the screws neatly organised and labelled. Little touches make the difference!
Yeah love the little touches, your 970 would have looked great in this but see I have just missed out, I will get a half decent card soon :mad:
