7 Aug 2006 at 13:36 #1 shodan shodan Associate Joined 4 Jul 2006 Posts 212 Location London When installing an IO plate, are you supposed to remove the bits that are bent inwards and get in the way?
7 Aug 2006 at 13:37 #2 Maximum Pc Maximum Pc Permabanned Joined 6 Aug 2006 Posts 21 yes but most people just bend them the other way so you can connect lan cables and stuff
7 Aug 2006 at 13:39 #3 shodan shodan Associate OP Joined 4 Jul 2006 Posts 212 Location London Maximum Pc said: yes but most people just bend them the other way so you can connect lan cables and stuff Click to expand... So, bend them flat again?
7 Aug 2006 at 13:40 #4 Zefan Zefan Man of Honour Joined 15 Jan 2006 Posts 32,984 Location Tosche Station This has always confused me so I'ver never actually fitted one
7 Aug 2006 at 13:48 #5 t31os t31os Soldato Joined 24 May 2006 Posts 3,824 Location Surrey - UK Always bent them back myself, so they sit on top of the ports, if you know what i mean.
7 Aug 2006 at 14:06 #6 Tigjaw Tigjaw Associate Joined 6 Oct 2005 Posts 669 Location West Midlands I thought you were supposed to bend them back so they sprung up against the IO if you know what I mean.
7 Aug 2006 at 14:08 #7 sanofi sanofi Associate Joined 9 Jul 2006 Posts 1,848 Location Vienna Previous two posters have it right IMO. Push the metal covers inwards into the case so that they the actual ports sit between them.
7 Aug 2006 at 14:14 #8 shodan shodan Associate OP Joined 4 Jul 2006 Posts 212 Location London Ok Thanks!
