I have trouble running 'FullHD' on youtube and I suspect its down to flash not running GPU and only on CPU dependant. I heard one of the new Flash 10.1 / 10.2 beta or something utilises GPU now.
Might need some research. But yes it will spike and lag when running HD content on your ION.
Tried it on mine and it runs maybe 2-3fps, all 4 threads are about 90% so I suspect it's not offloading it onto the GPU as it plays Blu-Rays flawlessly.
Using firefox and I think the non free flash plugin 10.2.154 I get 70-80% on the cpu remember the celeron is faster than the Atom by around 20%
Playback is watchable but will occasionally judder when the machine is loaded with other tasks. I noticed the judder when my cronjobs running every 5 mins kicked in
My Boxee install is faffed up so swiftly moving on .....
XBMC - Now this is where it get interesting, I installed the iplayer addon and everything was as smooth as silk albeit it's playing at 25fps.
I noticed that it wasn't actually HD so went in to the preferences and changed desired video stream to 3500 kbps or whatever it was for best quality.
Back in to testing and it's smooth as silk
GPU usage I think peaked at 25%
CPU at 4-5% on each core
So moral of the story... iplayer or maybe flash player doesn't seem to be very optimised for the web... I mean even on a quad core the cpu usage is way higher than it should be
