iOS SABMobile
I know you've probably already checked this but try using the external IP over 3G and making sure the port is forwarded, same if you're connecting via a wifi hot spot or similar.
Instead of using [SABmachineInternalIP]:8000 you would use [YourExternalIP]:8000 - and port 8000, or whatever you have set SAB to use forwarded on your router to point to the internal IP of the SAB machine.
www.portforward.com might help with how to port forward on your router too.
Your likely to have a dynamic IP address too, might be an idea to setup dyndns and use that so you can always connect.
