IP Address change for OcUK webservers
Godfather
Godfather
17 Oct 2002
Bromsgrove
The IP addresses of our web servers changed at 3am last night. This change may result in an SSL Security Certificate match message during the checkout process for some customers. SSL is still working so please ignore the message. As soon as your ISP updates their DNS records this issue will disappear.
I have to login again, and certain avatars and the top right OCUK shop banner is missing, have refreshed etc, no worries will just clear everything and start again
Just a note - if your ISP is slow to update you can always try out OpenDNS (public DNS servers), they've updated their records already.
http://www.opendns.com (DNS servers are 208.67.222.222 and 208.67.220.220)
I changed my dad's DNS settings to this on his router connected via Telefonica in Spain 3 days ago and the speed increase was phenominal - went from feeling like a 56k connection to what it should be, a 6Mb connection, with that one change.
The forum is working with IE but with firefox it goes mental and loads the site, then says done, and then loads again really quickly.
And everyones avatar's are messed up apart from the admin ones.
In IE it also says http://91.151.218.11 instead of forums.overclockers.co.uk
Mine did that, then the next time it was fine.
I'm using my ISPs nameservers at the moment though, due to OpenDNS re-routing Google and it being very slow at night.
