Having had a look on the web without much success Im try to overclock on this board but nor stress the ram too much.
I have basically got a E6750 to 3ghz by raising the fsb to 375mhz. However this takes the ram upto 750mhz from the 666mhz it is at stock. I would rather the ram to run at normal speed and lock this speed whilst raising the fsb. However the ram options only have ratio's which up the ram speed and not lock it to 666mhz.
I know I really should be using 800mhz ram to start but I went for the cheap and nasty 666mhz
Can any of you help with advice on the current state of play?
