IP35-Pro - How to reduce fan speed?
20 Apr 2004
Hi all,
Just assembled my pc and it's a little bit noisy at the moment.
I would like to try reduce the cpu fan speed as I believe this is causing most of the noise.
I havent overclocked.
How do I go about doing this?
Go into the uGuru section of the BIOS and press the right arrow key.
That'll put you into the monitoring section of the BIOS.
Aaaaaaaaah.
I thought you meant the Abit IP35 Pro.
They'll still be a monitoring section anyway.
Does your CPU fan have 4 pins? If so then you need to select PWM in the BIOS.
