IP35 Pro Memory Issues
Man of Honour
17 Oct 2002
Hi guys.
Some background.
My machine was an IP35-Pro with 4Gb of OCZ Platinum (4x4Gb) and a Core2Duo. My other machine was a crap old A64.
So I upgraded both by getting a new IP35-Pro, a Q6600 and another 4Gb of ram, but this time 2x2Gb Corsair XMS2.
So I built my main machine using the new motherboard, OCZ memory and the Q6600. All works.
I took the old IP35-Pro and Core2Duo and installed into the other machine, using the new 2x2Gb Corsair memory.
Problems started.
Basically, if I use slots 1 and 3 for dual channel, the machine detects only 2Gb of ram at POST. If I use slots and 1 and 2, for example, then it works fine, detects 4Gb, but doesn't work in dual channel.
Until last night this board was working perfectly in my main machine with the 4 OCZ sticks in dual channel.
Any ideas guys?
Thanks!
Voltage is set to 2.2v, which is what the OCZ ran at. How would this stop it running in dual channel mode if it was incorrect?
