Im having several problems with the board, to start heres the spec
Q6600 @ stock (Core temp average 34C on idle, so HSF is fine)
Arctic freeer pro 7 (with the cpu header plugged in)
Ip35 Dark Raider (problem?)
2Gb Geil Ultra low (upped the voltage to the 2.1 due to the spd not reporting properly)
8800gt Leadtek with zalman, with the pci-e power in
620 Hx Corsair (with the 24pin, the 4 pin molex and the other 6 pin all plugged in)
500gb Samsung Spin point (got a 500gb aaks installed but no power until I get everything working)
Soundblaster Ausidy 4
XP sp2 and all updates possible
Now the issues:
It doesn't recognise any of the contents of a usb pen drive thing, no idea why as other PCs do, see below.
It double boots from cold, maybe a BOS problem?
I can only put the SATA emulation thing to IDE in BIOS, any other setting it doesn't boot even though Ive installed the chipset drivers and dont understand how to get to work as SATA ACHP or whatever.
Further development:
When accessing large files of the usb drive, i.e. Sound blaster drivers, its crashes and then fails to recognize the contents of the drive.
Then it requires uninstalling then reinstalling (of the usb drive) for it to work again.
Any ideas?
Help would be very much appreciated, thanks in advance, Sukh
Now the issues:
Any ideas?
