IP35 with e8400
27 May 2007
Leeds!
just a quick one does anyone know if that cpu works on that board?
before you say check the site i did already and they dont list anything above the e68XX range on there cpu list so i was rather hoping for first hand yes/no
assuming that we are talking abit IP35 it will work although you'll probably want to update the BIOS to get the reported temps sensible.
If you are talking the J&W board it also work, straight out the box. Still recommend you to update to bios 1.3b which at the moment is the best bios imo.
