Ipad 2 damged case, how much to fix?
31 May 2009
Damaged ipad2, it was dropped on its end, the case around the power button is a bit squashed, and as such the button wont depress repress, and might get caught if pressed hard.
The alternative shut off of holding the home button for ages works, as do all the functions of the ipad2, except screenshot involving both buttons.
How much would it likely cost to get this fixed?
It might simply involve replacing the back part of the casing, or might need the power button also.
Could be costly as everything attaches to the back. For example the battery is glued to the chassis.
Might be worth saving your pennies and buying an air or air 2.
