Ipad 3 glass lifting ?
11 Oct 2005
Derbyshire
Hi bought a second hand ipad 3 16gb 3G few weeks back. Works fine etc. But noticed this yesterday. It is purely cosmetic but just wondered if there was any "simple fix" to seal this again?
Just lifting a bit on bottom left corner from home button
Thanks
(Could this have been replaced at some point? Is that why it is like it is)
looks like the digitizer have been repaired at some point and the the adhesives they used isnt strong enough so that's why it is lifting.
simple fix would mean you have to reseal by removing the whole digitizer then remove the old adhesives and reseal with better grade adhesives.
