Ipad Pro 10.5 Battery Capacity
17 Oct 2002
Leeds
Hi there
My iPad Pro 10.5 battery charge is 7800mah but the capacity is 8134mah. It is brand new with only 10 complete charge cycles. This is according to Battery Life and Aida64. Is it normal for the charge to not be the rated 8134mah capacity?
It's likely by design - perhaps the battery is saving cell rows for when the main battery starts dying, it will then start using the 'untouched or perfectly preserved cells' for continued use - maybe?
