Good afternoon guys.
Im having issues with charging on my daughters iPad I've exhausted all avenues user end and the next step is professional help.
It started around 12 months ago , it use to charge via any cable then certain ones and lastly in recent months it only charged by a Razer cable i got supplied with a set of headphones which is odd but still charged non the less.
Last two weeks i managed to get it charged just once and its totally had its day, I've followed all tutorials on and done a hard reset and bought a cleaning kit on amazon to try and sort which did actually work once but never again.
The weird thing is if the ipad is turned off and i insert a charge cable the ipad turns on but still doesnt charge
Ive been told apple will not repair it (No apple care) they will just swap for new unit for like £600, i watched a guy on youtube charging the charge port so deffo no thanks on that ha
Found people to do a charge port change and its £206 quid.
An alternative I've got is buying a magic keyboard which uses passthrough charging and i can charge the ipad via the usbc on the keyboard still an expensive fix (£120 used) and she doesn't necessarily need a keyboard.
Ive google other options is anybody aware or found a fix of a 3rd party device that would charge the ipad without the need of an expensive keyboard add on.
Bit against the clock as we are heading on holiday in 5 weeks and need a solution.
Happy to try anything else i may have overlooked.
thanks for reading Adam.
