Hi,
I have a couple of questions which I would like some help with.
1. I have the 3G version of the iPad and was wondering if the GPS is active if I do NOT have a internet/sim card installed?
I am planning on on using this as I travel a little bit and wanted to know if the GPS will work without the sim card.
If it doesn't, is there a way toget it working?
A friend mentioned buying a 'pay as you go' sim just to get it active, but I dont want to do that unless I now it will work.
2. Can I stream movies that I have downloaded to the iPad on to my TV? I though that there were two possible ways of doing this - trough my PS3 or through the apple TV box (which I do NOT own).
Are either of these ways possible or is there a simpler method?
Regards
Lee
Regards
Lee
