17 Oct 2010 at 19:14 #1 Rooky007 Rooky007 Soldato Joined 18 Oct 2002 Posts 3,642 Ok Folks I been trying to find the right answer on here but cant really find one.. I bough myself a new Panasonic Camera LX5 and the Manuel is on the CD as a PDF Format... How do I get this readable on my ipad??
17 Oct 2010 at 19:21 #2 ^187 ^187 Associate Joined 17 Nov 2005 Posts 1,037 Location Leeds One way is to import into iTunes, it will be in iBooks under the PDF section. :>
17 Oct 2010 at 19:24 #3 Rooky007 Rooky007 Soldato OP Joined 18 Oct 2002 Posts 3,642 How do i import it into itune from my Mac?
17 Oct 2010 at 19:30 #4 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,136 Location In the radio shack Install iBooks (it's free). Connect your iPad, select it under 'devices' in the sidebar in iTunes. Click on the Apps button at the top in the panel on the right. Towards the bottom of the screen you'll see a section called File Sharing. Click on iBooks and then drag/drop your pdf onto it or click the 'add' button right at the bottom.
17 Oct 2010 at 21:29 #5 Rooky007 Rooky007 Soldato OP Joined 18 Oct 2002 Posts 3,642 Thanks now sorted
18 Oct 2010 at 17:57 #6 Qdos Qdos Associate Joined 29 Feb 2008 Posts 911 Location London Or as an alternative, Goodreader works in exactly the same way (if you didn't want to use iBooks)
18 Oct 2010 at 18:50 #7 ethos ethos Soldato Joined 5 May 2003 Posts 4,515 Location UK OR Stanza, which I personally prefer out of iBookes and Goodreader. It opens my larger PDFs a lot quicker and generally seems snappier
