Hi.
I want to replace WM2003SE on a HP 4700 ive got with WM6.
Am i correct in thinking that replacing it with one of the cooked ROMs for a 4700 will work fine? Odd question i know.
Also, is there a way to install TomTom on it without having to install the dodgy PC software?
The existing memory card for the device has the UK maps on it, so is there a WM installer somewhere that i can just wack on the device and have it pick up the maps on the memory card?
Thanks in advance all .
