iphone 11 split screen display
23 Jan 2005
Hi if my daughter swipes to the left or right from the home screen her display splits in two and she either gets a widget or app library screen appearing on the right hand side of the home screen. anything she can try to restore to normal ?
Thanks
should say i asked her to check that the display wasn't on zoom after a google search
Thanks all turns out it’s fine now after a week of it showing split screen so can’t update other than that
Thanks
