iPhone 13 Pro - Kernal Panic DCP: screen keeps glitchingm going black and phone restarts help.
19 Oct 2002
Shakespeare’s County
My iphone 13 pro is playing up and looks like something to do with the DCP sensor? Any experience or advice, its rebooting a lot before i even get chance to get into the anlytics and after a restore i have same issue but currently waiting recovery of my AppleID as the phone i used for 2FA i no longer have.... Doh!
Thanks
Brief update. Seems no SIM card and the phone is happy, SIM card in and the crash reboot cycle reappears. Tried eSIM today and the error persists until i turn it off so deffo an antenna issue atleast.
"panicString" : "panic(cpu 0 caller 0xfffffff031da2ae8): DCP SERROR
Incase it’s of any use to anyone? I think it’s Genius Bar time!
Hello, i have the same issue with an iphone at my repair shop, did you find the issue?
Not yet, booked genius bar but gonna try my bank / vodafone cover.
Weird thing is it works fine in strong signal areas and also if its charging but anywhere it starting hunting for 3G it reboots. Just being using on Wifi and using wifes hotspot (oo matron) when out and about.
