iPhone 14 cases
23 Jan 2005
I seen it mentioned in a few places but no actual thread about what cases are we buying for the new iPhone range, so decided to ask here, what would you get for a pro in purple ?
Thanks
I think the purple is a tricky one to match a case with which is why I eventually went black.
The Apple Ink in leather seems to be the one intended to go with it, but the photos I’ve seen show it as blue rather than purple. I’d still give it a go though and would also try Midnight and a clear case to show off the colour. But not the Apple one as it doesn’t protect the bottom.
I’ve gone Umber and Ink in leather plus a Mous clear one. £170 on cases seems more than enough!
Have a spigen in hand and will be getting an apple official (both clear mag safe ones) - will report back on Fri/Sat with thoughts.
Okay you probably have your new iPhones in their cases for a while now, hopefully I get mine in a little over a week, so can I ask for anyone who has a purple pro what case you went for and are you happy with it as I will be ordering next week to have it ready ?
Thanks
Thanks
Purple here. Looks fantastic. Why put it in a case? They just ruin it.
Went with the Spigen Tough Armour one myself in case the phone falls on the floor when jogging. Expecting it tomorrow.
Spigen Ultra Hybrid MagFit Case Compatible with iPhone 14 Pro - White https://amzn.eu/d/dMRhiZt
I went for this one, usually I don’t go for clear cases but with the deep purple, it’s hard to cover it. I didn’t pay £27, think I paid about £18 for it from Amazon, some sort of voucher they were offering.
It’s a very tight fit though on my 14pro. It will probably yellow after awhile but that’s to be expected.
I was going to go for the official apple leather case, I have the pacific blue on my 12pro and it looks really tacky now. It hasn’t patina’d well and from what I have read it’s because they use a different cheaper leather than they used to. Not sure how true that is though.
Is the case sort and flexible or like a hard shell case, also how noticeable is the MagSafe?
Thanks
Thanks
It’s not soft as in quite flexible but it will flex enough to put the phone in and out.
The ring is noticeable depending on what version you go for, I actually ended up going for the graphite version as I think the MagSafe ring is bit more understated than the white ring. My wife has a white version on her iPhone 13 and it’s very noticeable.
As I said previously the case is quite a tight fit though.
But I do like it as it shows the deep purple off quite nicely.
Also because I bought it from Amazon, if I didn’t like it I could easily return it for a refund.
Thanks I went for this one Case but I would like to see the purple colour
Can’t see which one that is.
The one I have mentioned above is clear but last night in low light the phone looked graphite but in daylight it shows as deep purple.
Quite cool if you ask me hehe, 2 tone colour.
