- 5 Nov 2004
does the o2 carrier allow you to send mms message yet if you installed the 3.0 GM?
Yes, you don't need to do anything. Settings are built into 3.0 GM.does the o2 carrier allow you to send mms message yet if you installed the 3.0 GM?
Absolutely. http://i.gizmodo.com/5284779/iphone-os-30-now-available-in-torrent-tested-it-worksSo its safe to install 3.0 GM ?
They did say in the original keynote that it would reduce battery by about 20% i belive was the number but it will reduce it, I never got two days from my iphone even on standby and I have had 9 3G's (with various build quality and screen issues) all had the same battery life of 1.5 days intermittent low use with low screen brightness and 3g on, wifi on makes no difference in my experience.
I just hope it lasts to the end of they day as i charge it nightly.
Really? I get a solid 3 days out of mine, 4 with liberal useage.
I took it on a trip to france and forgot my charger - it finally died 4 days later on the motorway home, and I'd been using it quite a bit - texting, phoning the mrs on an evening, internet useage and even google maps to plot biking routes.
3-4 days?! I'm lucky to get 24hours. I have mine in the dock at work and at home most times so I don't notice now but I used to have the phone regularly die overnight on me
