Iphone 3.0 - Wifi no longer connects
8 Sep 2007
Anyone else having this problem?
I updated to 3.0 yesterday while at work and my phone lost the saved wifi passwords, no big deal I thought, and after entering about 6 times it connected to my work router. Went home and couldn't connect to my home router at all despite many attempts.
Back at work today and now can't connect to the router here again. Called 02 and was told all they are doing today is listening to problems, and call back tomorrow for any kind of help !?
Tried a full reset but still not working - any ideas?
I had the same problem yesterday tried hard reset, deleting and re-doing the Wifi setup and nothing worked, I finally tried the "reset network settings" option in the Reset folder in settings and all is well now...
Give it a go...
Thanks Scientific - just tried that but still no luck.
I can see the network but when I try and join get the message 'unable to join network'.
Is there any way to undo the update?
when you said you tried a full reset do you mean holding down the home and power buttons?
If not do that as well, the only other thing I can think of is to restore the phone back to factory settings and see if that works
