iPhone 3G PayG Wifi Access
7 May 2003
Leytonstone
Sorry if this has been covered already, I looked but couldn't find a simple answer.
I have got an iPhone 3G on O2 PayG and it includes 12 months 3G & Wifi access, only I can't find any information reagrding the Wifi side of things.
I assume I will need a Logon/Password from O2, but nothing in the documentation I got with it or that I can find easily on the 02 website explains how I go about getting hold of this.
If anyone could tell me what I have to do to request a login/password, I would appreciate it.
Cheers
JudgeC
If I remember correctly, if you come across a Cloud or a BT OpenZone wireless network while using your iPhone, you will be prompted with a website asking you to enter the mobile number of your SIM card in order to grant you access to the network :)
Ah that sounds nice and easy. :)
Thanks for the info.
I just got an iPhone 3G yesterday and was wondering the exact same thing, thanks for the clarification.
As has been said the iPhone Bolt-On gives you Cloud access. You just enter your phone number when prompted and then everytime you enter The Cloud it connects (assuming you keep WiFi on)
It's cool because you only have to enter the phone number once, then it registers your MAC address so unless you change phones you won't need to do it ever again.
