Iphone 3GS & Bluetooth Car Kit recommendations
26 Oct 2002
East Sussex
Hi Peeps,
I am after a bluetooth car kit for the Iphone, has anyone got one? If so does it work all the time and would you recommend it?
For calls? I've currently got a Parrot CK3200 and it works fine with the iPhone so that's what I'd recommend.
Yep - the Parrott is what I have. Great in car kit. Only problem though is the iPhone is incredibly fussy. In mine and one of the bosses (not tried anymore than just our two) if any other phones are paired with the Parrott it fails to pair with the iPhone. Simply deleting the other paired devices it works right away.
Odd.
My Parrot is paired with my work BB Bold and my iPhone and it works flawlessly with both - sounds like a Parrot software issue, not the iPhone ;)
Mmmm, could be I guess. A quick google suggested it was a little more widespread - I may fire an email off to Parrott and see what the official line is.
Thanks for the replies, Yeah just for calls Off to check the Parrot out. I assume it just works by pairing it up? no need to wire into the stereo? I know some of their devices often require that.
