Hi All,
I had cracked the screen of my Iphone 3gs, so bought a home repair kit from ebay, i got through most of it okay, but when it came to removing the cracked glass from the casing, the number 3 connector tape ripped (hope that makes sense).
Does anyone know what this outer casing part is called and what i need to fix it?
Thanks.
Thanks.
. 2 screws, and then (very gently) pull the glass up using the correct tools (mini suction cup will do it). Then carfully disconnect the 2 push on cables, release the catch on cable 3 and then it pulls out. Remove 6-7 screws form the screen/digitiser assembly and then carefully removed the LCD and clean the inner glass and LCD, re-assemble and you're done!
